- 1
- 2007-10-21
请问COMSOL4.0的版本在做热-结构(Thermal-Structural Interaction)的时候,能够做双向耦合吗?也就是文献里面常提到的紧耦合,完全耦合?
我看COMSOL的帮助文档(sme_ug.pdf),里面提到的热——结构耦合是one-way coupling,只能温度影响结构变形,而结构变形不影响温度,即热传导不能有变形项,我将原文附下:
The Structural Mechanics Module provides a predefined one-way coupling for
thermal-structure interaction (thermal stress), which combines a solid mechanics
interface from the Structural Mechanics Module with a heat transfer interface from the
Heat Transfer Module or COMSOL Multiphysics; see The Thermal Stress Interface.
By default, COMSOL Multiphysics takes advantage of the one-way coupling and
solves the problem sequentially using the segregated solver: first solve for temperature
and then perform the stress-strain analysis using the computed temperature field from
the heat transfer equation. Note that this approach, using a single iteration, does not
produce a correct result if there are thermal properties that depend on the
displacements (for example, mechanical heating), making it a two-way coupled
problem.
还有一个问题,就是即使是单向耦合,COMSOL能计算热振动问题吗? 我不仅仅需要热应力,我更加关心的是振动问题(有机械载荷)
