- 66
- 2005-5-30
PATH: /tm/cd35 TYPE: Status-Simulation Structure to evaluate in SIMCODE prologue is WriteInputFiles latch3000cmd
PATH: /tm/cd35 TYPE: Status-Simulation Prologue statement WriteInputFiles latch3000cmd executed successfully. - 0
PATH: /tm/cd35 TYPE: Status-Simulation SimServer<TaskHost=jujumao/SimHost=jujumao> Simcode adams3000 command to execute is: "./goAVIEW3000.bat"
PATH: /tm/cd35 TYPE: Status-Simulation User environment restored for Simcode adams3000.
D:\OPTDIR\P3XZYS>del D:\OPTDIR\P3XZYS\disp3000.txt
D:\OPTDIR\P3XZYS>"C:\MSC.Software\Adams\MDR2\common\mdi.bat" av ru-s b D:\OPTDIR\P3XZYS\latch3000.cmd e
????? 1 ???????
????? 1 ???????
PATH: /tm/cd35 TYPE: Status-Simulation SimServer<TaskHost=jujumao/SimHost=jujumao> Simcode adams3000 ran successfully.
PATH: /tm/cd35 TYPE: Status-Simulation Structure to evaluate in SIMCODE epilogue is ReadOutputFiles disp3000txt
PATH: /tm/cd35 TYPE: Error-Descfile ERROR messages from output parse=
PATH: /tm/cd35 TYPE: Error-Descfile WARNING: Automatically setting (preferences noreturn) because your
file parsing actions refer to (File_End).
For backward compatibility with earlier versions of iSIGHT,
(preferences noreturn) allows file parsing to continue when certain
exceptional conditions occur, but the recommended behavior is to
terminate file parsing when these exceptions occur. The latter
promotes better performance by eliminating the need for explicit error
handling in your file parsing actions.
If you do not want your file parsing actions to execute an automatic
return when (File_End) or an error is encountered, you should add the
following command to your actions before referring to (File_End):
Alternatively, if you want to immediately terminate file parsing when
(File_End) or an error is encountered, you should add the following
command to your actions before referring to (File_End): |
