查看: 138|回复: 4
Matlab Google Earth 工具箱
发表于 2010-5-17 11:06:15 | 显示全部楼层 |阅读模式 来自 上海
Google Earth 工具箱
http://www.mathworks.com/matlabcentral/fileexchange/12954
DescriptionOther Major Contributing Author(s):
Jurriaan H. Spaaks
The projects svn repository can be found at:
http://code.google.com/p/googleearthtoolbox/
You are welcome to join and contribute, or simply just use it. Either way have fun.
With the MATLAB functions within this toolbox, one can display spatially and temporally distributed data within Google Earth. It may be argued that converting the results of models and measurements to be able to view them in Google Earth is unnecessary since they can also be viewed within MATLAB itself. However, using Google Earth for evaluation of data can have some major advantages, a few of which are listed below:
1) very intuitive tools for navigating the view
2) retrieval of data from objects within the viewer
3) quick rendering of large files
4) interactively choosing which objects should be displayed
5) dynamic representation of time-variant data
Note: You must add the toolbox to your matlab path before you can use it or access help from the matlab start menu. For example:
>>addpath('D:\matlab\googleearth')
from the command window.
MATLAB releaseMATLAB 7.2 (R2006a)
Other requirementsQuestions/Problem
前一阵子搞了一下将matlab的数据导出为kml文件,显示在google earth中。现在要反过来了,准备将google earth中的数据,导入到matlab中。
欢迎兄弟们来讨论一下。谢谢!
发表于 2010-5-17 11:11:32 | 显示全部楼层 来自 湖北武汉
Googel Earth对于我们地质行业是个好东西。
对于陌生的矿区,交通,位置,植被,高程情况一目了然。
发表于 2010-5-18 14:48:52 | 显示全部楼层 来自 湖北武汉
哦,我也是搞地质的,学习学习!
 楼主| 发表于 2010-5-18 15:55:11 | 显示全部楼层 来自 上海
你们搞地质,能否把google earth中的高程数据提取出来?
发表于 2010-5-19 09:12:40 | 显示全部楼层 来自 湖北武汉
我也想提出来,好像很难,还有遥感图像的数据也提不出来啊
GMT+8, 2024-10-6 23:16 , Processed in 0.053061 second(s), 18 queries , Gzip On, MemCache On.
