查看: 23|回复: 0
材料设置非线性以后求解出现警告
发表于 2010-6-1 21:34:36 | 显示全部楼层 |阅读模式 来自 陕西西安
材料设置常物性的时候正常,若设置非线性时就会有如下警告,这个怎么解决:
*** WARNING ***                         CP =      65.750   TIME= 21:36:49
The program chosen initial timestep/load-factor is arbitrary.  It is
necessary for the user to supply a suitable initial
timestep/load-factor through the NSUB or DELTIM command for
convergence and overall efficiency.
*** WARNING ***                         CP =      73.234   TIME= 21:37:02
Material property KXX of material 1 of element 7801 is evaluated at a
temperature of 0, which is below the supplied temperature range.
Temperature range checking terminates.
GMT+8, 2024-9-20 19:45 , Processed in 0.043787 second(s), 13 queries , Gzip On, MemCache On.
