- 2006-4-18
各位好!
刚开始学习Origin,在做软件里自带的例子“Fitting One Dataset as a Function of Other Datasets”时,按照教程一步步做完,拟合结束后在FitNLcurve1面板中,未能找到拟合曲线的函数值,只有残差,请问如何设置,以便直接获得拟合的函数值?按照教程中的说法,可以在该面板直接得到拟合值,然后复制粘贴到原工作表进行对比。
To verify the fitted results, you can add a new column and Copy + Paste the fitted value, which comes from the fitted Y in the worksheet FitNLCurve1, into it. Then Highlight the Composite and the fitted data and plot a line graph to see how good the fit is: |
