- 17
- 2009-3-3
发表于 2011-1-24 11:16:23
来自 湖南长沙
MPC184 comprises a general class of multipoint constraint elements that apply kinematic constraints between nodes. The elements are loosely classified here as “constraint elements” (rigid link, rigid beam, and slider) and “joint elements” (x-axis revolute, z-axis revolute, universal, slot, point-in-plane, translational, x-axis cylindrical, z-axis cylindrical, x-axis planar, z-axis planar, weld, orient, spherical, and general). The constraint may be as simple as that of identical displacements between nodes. Constraints can also be more complicated, such as those modeling rigid parts, or those transmitting motion between flexible bodies in a particular way. For example, a structure may consist of rigid parts and moving parts connected together by rotational or sliding connections. The rigid part of the structure may be modeled with the MPC184 link/beam elements, while the moving parts may be connected with any of the MPC184 joint elements. |
