在对多体零件独立剖分网格后,出现如图所示的问题,在2这个部分,显示的不是完整的对号,而且在最后的计算中显示
No control surfaces have been found for the domain interface
Default Fluid Fluid Interface
If you expect this to occur, please set the expert parameter
'ggi permit no intersection=t' to work around this message.
Possible setup errors leading to this situation are:
1. An incorrect axis of rotation for a rotating domain or domain
interface.
2. A frame change model is used in which there is unequal pitch
shapes, or circumferential orientation, but the Pitch Change
model is set to None.
3. The transient rotor stator model is used when the geometry
does not span 360 degrees and the Pitch Change model is set to
None.
不知道是不是因为剖分的问题,有什么遗漏的地方导致最后不能正确计算么?
真心求各位前辈解答
