- 4
- 2005-3-21
发表于 2005-4-3 22:44:25
来自 广东广州
Re:FASTSHIP中文翻译小组开张(同时继续吸收成员)
说到翻译,我想请问一下使用过Fastship的朋友
在Tutorial
1.7 Starting a Hull Design中有一段是这样的:
“At this point, we have a surface that is a good start to the profile shape of the hull. The forefoot, however, is still a sharp corner. We need to round this off, with a technique known as "corner wrap". Corner wrapping provides both slope and curvature continuity from the stem to the bottom curve.
Zoom in on the bow area, and select Construct/Marker/G2Mix (Corner Wrap). You will be prompted to click on the two vertices that are aft of the corner, and then the two vertices above the corner. A construction marker will then be drawn, showing the location where the corner vertex should be moved to ensure continuity around the corner. With the selection tool (), move the point to the marker. To make sure that the vertex goes exactly on the marker, use the "Snap to Construction Geometry" button in the Snap Filters toolbar(). Your net should look like the following:”
我估计其实就是倒圆角,可总是不能正确的操作,很是困扰
就算翻译成中文,如果操作不正确,也不行
请大家指导 |
