楼主: fpemail
[共建]<ANSYS命令流实例库>敬请您的加盟
发表于 2005-12-8 22:44:33 | 显示全部楼层 来自 黑龙江哈尔滨
Re:[共建] <<ANSYS命令流实例库>> 敬请您的加盟
我自己作了一个二层框架静力分析,自己觉得比较好的是可以显示四个窗口希望高手多多指点
FINI
/cle
/PREP7
ET,1,188
ET,2,63
sectype,1,beam,rect
secdata,0.3,0.3
sectype,2,beam,rect
SECOFFSET, USER,0, -0.2
secdata,0.3,0.5
mp,ex,1,3e10
mp,prxy,1,0.2
mp,dens,1,2500
r,2,0.1
K,1,0,0,0
K,2,6,0,0
K,3,6,6,0
K,4,0,6,0
KGEN,3,1,4,,,,3
*do,i,1,4
l,i,i+4 $l,i+4,i+8
*enddo
*do,j,5,7
l,j,j+1 $l,j+4,j+5
*enddo
l,5,8 $l,12,9
lsel,s,,,9,10
latt,1,,1,,1,,2
lsel,s,,,15,16,
latt,1,,1,,1,,2
lsel,s,,,3,4
latt,1,,1,,1,,1
lsel,s,,,7,8
latt,1,,1,,1,,1
lsel,s,,,11,12
latt,1,,1,,3,,2
lsel,s,,,13,14,
latt,1,,1,,3,,2
lsel,s,,,1,2
latt,1,,1,,2,,1
lsel,s,,,5,6
latt,1,,1,,4,,1
lsel,all
esize,0.5
lmesh,all
type,2
real,2
A,5,6,7,8
A,9,10,11,12
esize,0.5
Amesh,all
nummrg,all
numcmp,all
finish
/solu
DK,1,all
DK,2,all
DK,3,all
DK,4,all
ACEL,0,0,9.8
F,345,fz,-100000
F,466,fz,-100000
allsel
solve
fini
/POST1
/WIND,ALL,OFF
/WIND,1,LTOP
/WIND,2,RTOP
/WIND,3,LBOT
/WIND,4,RBOT
GPLOT
/GTYPE,ALL,KEYP,0
/GTYPE,ALL,LINE,0
/GTYPE,ALL,AREA,0
/GTYPE,ALL,VOLU,0
/GTYPE,ALL,NODE,0
/GCMD,1,ELEM
/GCMD,2,PLDI,0
/GCMD,3,PLNS,U,Y,0,1
/GCMD,4,PLES,S,Y,0,1
FINI
/cle
/PREP7
ET,1,188
ET,2,63
sectype,1,beam,rect
secdata,0.3,0.3
sectype,2,beam,rect
secdata,0.3,0.5
mp,ex,1,3e10
mp,prxy,1,0.2
mp,dens,1,2500
r,2,0.1
K,1,0,0,0
K,2,6,0,0
K,3,6,6,0
K,4,0,6,0
KGEN,3,1,4,,,,3
*do,i,1,4
l,i,i+4 $l,i+4,i+8
*enddo
*do,j,5,7
l,j,j+1 $l,j+4,j+5
*enddo
l,5,8 $l,12,9
lsel,s,,,9,10
latt,1,,1,,1,,2
lsel,s,,,15,16,
latt,1,,1,,1,,2
lsel,s,,,3,4
latt,1,,1,,1,,1
lsel,s,,,7,8
latt,1,,1,,1,,1
lsel,s,,,11,12
latt,1,,1,,3,,2
lsel,s,,,13,14,
latt,1,,1,,3,,2
lsel,s,,,1,2
latt,1,,1,,2,,1
lsel,s,,,5,6
latt,1,,1,,4,,1
lsel,all
esize,0.5
lmesh,all
type,2
real,2
A,5,6,7,8
A,9,10,11,12
esize,0.5
Amesh,all
nummrg,all
numcmp,all
finish
/solu
DK,1,all
DK,2,all
DK,3,all
DK,4,all
ACEL,0,0,9.8
F,345,fz,-100000
F,466,fz,-100000
allsel
solve
fini
/POST1
/WIND,ALL,OFF
/WIND,1,LTOP
/WIND,2,RTOP
/WIND,3,LBOT
/WIND,4,RBOT
GPLOT
/GTYPE,ALL,KEYP,0
/GTYPE,ALL,LINE,0
/GTYPE,ALL,AREA,0
/GTYPE,ALL,VOLU,0
/GTYPE,ALL,NODE,0
/GCMD,1,ELEM
/GCMD,2,PLDI,0
图片我不会插入,大家自己运行看一下吧!
liuhuafeng1126 该用户已被删除
发表于 2005-12-9 09:31:20 | 显示全部楼层 来自 江苏南京
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2005-12-13 13:38:32 | 显示全部楼层 来自 重庆
有关于ansys模拟徐变方面的么?各位大侠
发表于 2005-12-18 18:52:39 | 显示全部楼层 来自 北京
一个接触分析的APDL命令流
给出了接触定义的一般方法
/TITLE,Analysis of a Axis Contacting a hole in a Disc   !定义标题
/PREP7
ET,1,SOLID185                    !定义单元类型
MP,EX,1,2.1E5                     !定义材料属性
MP,PRXY,1,0.3
CYL4,0,0,34,0,100,90,25             !创建四分之一圆环
CYL4,0,0,25,0,35,90,150
VGEN, ,2, , , , ,-10, , ,1               !移动轴
LESIZE,17, , ,15, , , , ,1                !定义线的分网尺寸
LESIZE,19, , ,15, , , , ,1
LESIZE,18, , ,2, , , , ,1
LESIZE,20, , ,2, , , , ,1
LESIZE,22, , ,20, , , , ,1
LESIZE,5, , ,10, , , , ,1
LESIZE,7, , ,10, , , , ,1
LESIZE,6, , ,8, , , , ,1
LESIZE,8, , ,8, , , , ,1
LESIZE,10, , ,3, , , , ,1
VSWEEP,ALL                   !用扫掠方式对创建的体进行网格划分
/COM, CONTACT PAIR CREATION - START
MP,MU,1,0.2                    !定义接触摩擦系数
MAT,1
R,3                            !定义接触实常数
REAL,3
ET,2,170                        !定义接触单元类型
ET,3,174
R,3,,,0.1,0.1,,
NROPT,UNSYM
!* Generate the target surface       下面创建目标面
ASEL,S,,,4
CM,_TARGET,AREA
TYPE,2
NSLA,S,1
ESLN,S,0
ESURF,ALL
!* Generate the contact surface    下面创建接触面
ASEL,S,,,9
CM,_CONTACT,AREA
TYPE,3
NSLA,S,1
ESLN,S,0
ESURF,ALL
CMDEL,_TARGET
CMDEL,_CONTACT
ALLSEL,ALL
EPLOT
FINISH
/SOLU                      进入求解器
DA,5,SYMM                 !定义面的对称位移边条
DA,6,SYMM
DA,11,SYMM
DA,12,SYMM
DA,3,ALL,                   !定义面的位移约束条件
ANTYPE,0                    !指定分析类型为静力分析
NLGEOM,1                    !考虑大变形影响
AUTOTS,0
TIME,100
SOLVE                        !求解第一载荷步
NSUBST,150,10000,10
OUTRES,ALL,ALL
AUTOTS,1
TIME,250
NSEL,S,LOC,Z,140               !选定轴向坐标为140的所有节点
D,ALL,UZ,40
ALLSEL,ALL
SOLVE                         !求解第二载荷步
/EXPAND,4,POLAR,HALF,,90       !进行模型扩展
/REPLOT
/POST1                         !进入同样后处理器
SET,1,LAST,1,                   !指定查看的载荷步
PLNSOL,S,EQV,0,1               !查看等效应力的云图
SET, , ,1, ,120, ,
ESEL,S,ENAME,,174
EPLOT
PLNSOL,CONT,PRES,0,1
PLNS,S,EQV
ANDATA,0.5, ,1,0,0,1,1,1              !查看动画显示
/POST26
RFORCE,2,925,F,Z, FZ_2              !定义约束反力变量
PLVAR,2,                           !绘制变量-时间曲线
FINISH
发表于 2005-12-19 18:04:53 | 显示全部楼层 来自 江苏南京
格栅夹层板的非线性分析
我做的是个格栅夹层板的非线性分析,下面是命令流
/clear,all
/config,nres,50000
/prep7
mp,ex,1,206000
mp,prxy,1,0.3
!mp,dens,1,7.850e-9
tb,bkin,1
tbdata,1,235,0
h=11.5
s=16.3
et,1,beam189,rect
sectype,1,beam,rect
secdata,1.22,1.22
k,1
k,2,s
k,3,s,s
k,4,0,s
k,5,s/2,s/2,h
l,1,5
l,2,5
l,3,5
l,4,5
latt,1,0,1,,,,1
lesize,all,,,5
lmesh,all
lsel,all
lgen,9,all,,,s
lgen,6,all,,,,s
et,2,shell143
r,2,0.55
sect,2,shell
secdata,0.55,1
rectng,0,s,0,s
wpoffs,,,h
rectng,0,s/2,0,s/2
rectng,0,s/2,s/2,s
rectng,s/2,s,0,s/2
rectng,s/2,s,s/2,s
asel,all
aatt,1,2,2,,2
aesize,all,s/10
amesh,all
agen,9,all,,,s
agen,6,all,,,,s
allsel,all
nummrg,all
numcmp,all
lsel,s,loc,z,0
lsel,r,loc,x,0
dl,all,,all,0
lsel,s,loc,z,0
lsel,r,loc,x,9*s
dl,all,,all,0
lsel,s,loc,z,0
lsel,r,loc,y,0
dl,all,,all,0
lsel,s,loc,z,0
lsel,r,loc,y,6*s
dl,all,,all,0
allsel,all
asel,s,loc,z,h
sfa,all,1,pres,-1.0
/replot
/solu
antype,0
pstres,on
solve
save
finish
/solu
antype,1
bucopt,lanb,5,0
mxpand,5
/solu
solve
save
finish
/prep7
upgeom,0.01,1,1,'file','rst'
/solu
antype,0
asel,s,loc,z,h
sfa,all,1,pres,-0.70
NLGEOM,1
stiff,on
OUTPR,BASI,ALL,
OUTRES,BASI,ALL,
solcontrol,on,,incp
RESCONTROL,DEFINE,ALL,1,1
CNVTOL,F,1000 ,0.01,2, ,
CNVTOL,M, 1000,0.01,2, ,
time,1
NSUBST,100
lswrite,1
antype,0
asel,s,loc,z,h
sfa,all,1,pres,-1.0
NLGEOM,1
stiff,on
OUTPR,BASI,ALL,
OUTRES,BASI,ALL,
solcontrol,on,,incp
CNVTOL,M,1000 ,0.01,2, ,
NSUBST,300
arclen,on
ARCLEN,1,12,0.0001
lswrite,2
LSSOLVE,1,2,1,
save
发表于 2005-12-21 09:45:49 | 显示全部楼层 来自 福建福州
一个超静定梁结构分析的命令流
由于水平所限,请多指教
/BATCH
/FILNAME,lianxi2                  !定义文件名
/UNITS,SI                         !定义国际单位制
KEYW,PR_STRUC,1                   !设置计算类型
/PREP7
ET,1,BEAM189                      !选择单元类型
MPTEMP,,,,,,,,                    !定义材料参数
MPTEMP,1,0
MPDATA,EX,1,,2.1e11
MPDATA,PRXY,1,,0.3
SECTYPE,   1, BEAM, HREC, , 0      !定义三个截面
SECOFFSET, CENT
SECDATA,0.04,0.06,0.003,0.003,0.003,0.003,0,0,0,0
SECTYPE,   2, BEAM, HREC, , 0
SECOFFSET, CENT
SECDATA,0.04,0.05,0.003,0.003,0.003,0.003,0,0,0,0
SECTYPE,   3, BEAM, HREC, , 0
SECOFFSET, CENT
SECDATA,0.05,0.05,0.002,0.002,0.002,0.002,0,0,0,0
/REPLOT,RESIZE
SAVE
K,1,,-0.6,,                !生成7个关键点
K,2,0.7,-0.6,,
K,3,0.7,-0.6,0.4,
K,4,1.5,-0.6,0.4,
K,5,1.5,-0.6,,
K,6,2.3,-0.6,,
K,7,3,-0.6,,
/PNUM,KP,1                 !打开关键点编号
FLST,3,7,3,ORDE,2
FITEM,3,1
FITEM,3,-7
KSYMM,Y,P51X, , , ,0,0     !镜面映射7个对称点
K,15,,-0.6,1,              !定义五个方向关键点
K,16,3,-0.6,1,
K,17,0.7,-0.6,1,
K,18,1.5,-0.6,1,
K,19,2.3,-0.6,1,
LSTR,       1,       2     !生成21条线
LSTR,       2,       3
LSTR,       3,       4
LSTR,       2,       5
LSTR,       4,       5
LSTR,       5,       6
LSTR,       6,       7
LSTR,       8,       9
LSTR,       9,       10
LSTR,       10,      11
LSTR,       9,       12
LSTR,       11,      12
LSTR,      12,      13
LSTR,      13,      14
LSTR,       1,      8
LSTR,       2,      9
LSTR,       3,      10
LSTR,       4,      11
LSTR,       5,      12
LSTR,       6,      13
LSTR,       7,      14
/PNUM,LINE,1               !打开线编号
LPLOT                      !显示线图形
FLST,5,4,4,ORDE,4          !给纵梁分配梁单元属性
FITEM,5,1
FITEM,5,4
FITEM,5,6
FITEM,5,-7
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,S,_Y
CMSEL,S,_Y1
LATT,1, ,1, ,       15, ,1
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
FLST,5,4,4,ORDE,4
FITEM,5,8
FITEM,5,11
FITEM,5,13
FITEM,5,-14
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,S,_Y
CMSEL,S,_Y1
LATT,1, ,1, ,      16, ,1
CMSEL,S,_Y                  !给横梁分配梁单元属性
CMDELE,_Y
CMDELE,_Y1
SAVE
CM,_Y,LINE
LSEL, , , ,       15
CM,_Y1,LINE
CMSEL,S,_Y
CMSEL,S,_Y1
LATT,1, ,1, ,       15, ,2
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,LINE
LSEL, , , ,      16
CM,_Y1,LINE
CMSEL,S,_Y
CMSEL,S,_Y1
LATT,1, ,1, ,       17, ,2
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,LINE
LSEL, , , ,      19
CM,_Y1,LINE
CMSEL,S,_Y
CMSEL,S,_Y1
LATT,1, ,1, ,       18, ,2
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,LINE
LSEL, , , ,      20
CM,_Y1,LINE
CMSEL,S,_Y
CMSEL,S,_Y1
LATT,1, ,1, ,       19, ,2
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,LINE
LSEL, , , ,      21
CM,_Y1,LINE
CMSEL,S,_Y
CMSEL,S,_Y1
LATT,1, ,1, ,       16, ,2
CMSEL,S,_Y                  !给发动机架上各梁分配梁单元属性
CMDELE,_Y
CMDELE,_Y1
CM,_Y,LINE
LSEL, , , ,      3
CM,_Y1,LINE
CMSEL,S,_Y
CMSEL,S,_Y1
LATT,1, ,1, ,       15, ,3
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,LINE
LSEL, , , ,      10
CM,_Y1,LINE
CMSEL,S,_Y
CMSEL,S,_Y1
LATT,1, ,1, ,       16, ,3
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,LINE
LSEL, , , ,      17
CM,_Y1,LINE
CMSEL,S,_Y
CMSEL,S,_Y1
LATT,1, ,1, ,      17, ,3
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
CM,_Y,LINE
LSEL, , , ,      18
CM,_Y1,LINE
CMSEL,S,_Y
CMSEL,S,_Y1
LATT,1, ,1, ,      18, ,3
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
SAVE
FLST,5,21,4,ORDE,2
FITEM,5,1
FITEM,5,-21
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1,0.5, , , , , , ,1    !控制21条线的单元尺寸
FLST,2,21,4,ORDE,2
FITEM,2,1
FITEM,2,-21
LMESH,P51X                      !划分线单元网格
/UI,MESH,OFF                    !关闭Meshtool对话框
/SHRINK,0                       !打开单元形状开关,以检验模型截面
/ESHAPE,1.0
/EFACET,1
/RATIO,1,1,1
/CFORMAT,32,0
/REPLOT
/SHRINK,0                       !关闭单元形状开关
/ESHAPE,0.0
/EFACET,1
/RATIO,1,1,1
/CFORMAT,32,0
/REPLOT
FINISH
/SOL                             !进入求解器加载
FLST,2,1,3,ORDE,1
FITEM,2,8
/GO
DK,P51X, , , ,0,UX,UY,UZ, , , ,  !加约束
FLST,2,1,3,ORDE,1
FITEM,2,14
/GO
DK,P51X, , , ,0,UY,UZ, , , , ,
FLST,2,2,3,ORDE,2
FITEM,2,1
FITEM,2,7
/GO
DK,P51X, , , ,0,UZ, , , , , ,
FLST,2,6,3,ORDE,6
FITEM,2,3
FITEM,2,-4
FITEM,2,6
FITEM,2,10
FITEM,2,-11
FITEM,2,13
/GO
FK,P51X,FZ,-1000                  !加集中力
/PSF,DEFA, ,1,0,1
/PBF,DEFA, ,1
/PIC,DEFA, ,1
/PSYMB,CS,0
/PSYMB,NDIR,0
/PSYMB,ESYS,0
/PSYMB,LDIV,0
/PSYMB,LDIR,0
/PSYMB,ADIR,0
/PSYMB,ECON,0
/PSYMB,XNODE,0
/PSYMB,DOT,1
/PSYMB,PCONV,
/PSYMB,LAYR,0
/PSYMB,FBCS,0
/PBC,ALL,,1
/PBC,NFOR,,0
/PBC,NMOM,,0
/PBC,RFOR,,0
/PBC,RMOM,,0
/PBC,PATH,,0
/REP
LPLOT
/STATUS,SOLU
SOLVE                                   !执行求解
FINISH
/POST1
SET,FIRST                               !读取第一步
/AUTO,1
/REP,FAST
/SHRINK,0
/ESHAPE,1.0
/EFACET,1
/RATIO,1,1,1
/CFORMAT,32,0
/REPLOT
PLDISP,1                                    !变形显示
/EFACE,1
AVPRIN,0, ,
PLNSOL,U,SUM,1,1                            !应力状态
! /EXIT,ALL
发表于 2005-12-21 10:03:47 | 显示全部楼层 来自 福建福州
欢迎原创的贴子!
本文纯系个人原创,并经ansys8.0调试成功,大家一起来杜绝抄袭!
发表于 2006-1-6 17:13:38 | 显示全部楼层 来自 湖北武汉
chenshi2003 你帖的那个隧洞的例子算不出结果,隧洞开挖后与开挖前是结果是一样的,怎么回事?
mechcui 该用户已被删除
发表于 2006-1-9 17:40:03 | 显示全部楼层 来自 黑龙江哈尔滨
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2006-1-13 14:46:38 | 显示全部楼层 来自 河南郑州
如下图所示,一吊桥。采用混凝土C30,吊杆的EA等于横梁EI的1/20m-2。试求吊桥结构的内力图。
fini
/clear
/prep7
et,1,beam3
et,2,link1
keyopt,1,6,1
mp,ex,1,3.0e10
mp,dens,1,2500
mp,prxy,1,0.13
r,1,0.18,0.3*0.6*0.6*0.6/12,0.6,
r,2,2.7e-4
k,1
k,2,60
k,3,,15
k,4,20
k,5,60,15
k,6,40
l,1,2
l,3,4
l,5,6
ldiv,1,,,60,1
ldiv,2,,,25,1
ldiv,3,,,25,1
lsel,s,,,4,63,1
latt,1,1,1
lmesh,all
lsel,s,,,64,88,1
latt,1,2,2
lmesh,all
lmesh,all
lsel,s,,,89,113,1
latt,1,2,2
lmesh,all
d,1,all
d,179,all
d,182,ux
d,182,uy
d,258,ux
d,258,uy
esel,s,,,61,120,1
sfbeam,all,1,pres,10000
cp,next,uy,59,255
cp,next,ux,59,255
cp,next,uy,119,331
cp,next,ux,119,331
allsel,all
/solu
solve
fini
/post1
etable,imom,SMISC,6
etable,jmom,SMISC,12
plls,imom,jmom,-1
etable,imom,SMISC,2
etable,jmom,SMISC,8
plls,imom,jmom,-1
发表于 2006-1-20 10:24:01 | 显示全部楼层 来自 福建福州
算动力简单例子
/prep7
et,1,16
et,2,21
r,1,0.375,0.1875
r,2,,,,31e-3
mp,ex,1,31.2e6
mp,prxy,1,0.3
n,1
n,2,8
e,1,2
type,2
real,2
e,2
m,2,rotx
outpr,basic,1
d,all,all
ddele,2,rotx
finish
/solu
antype,2
modopt,reduc,1,,,1
solve
/post1
*get,freq,mode,1,freq
发表于 2006-2-16 09:52:11 | 显示全部楼层 来自 湖北武汉
请教,杀死单元,活单元,死单元的作用,什么意思?
dx567 该用户已被删除
发表于 2006-2-22 15:39:12 | 显示全部楼层 来自 大连理工大学
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2006-3-10 16:42:38 | 显示全部楼层 来自 江苏南京
一个自己做的简单的例子,钢结构雨棚的分析
/prep7
k,1,          !!!!生成钢结构雨棚关键点
k,2,580,5.8
k,3,1880,18.8
k,4,3180,31.8
k,5,4480,44.8
k,6,5780,57.8
k,7,,2211
k,8,,2211,6900
*do,i,1,5
l,i,i+1
*enddo
lgen,5,1,5,1,,,1725
*do,i,9,26
l,i,i+6
*enddo
*do,i,1,6
l,i,i+8
*enddo
LDIV,24, , ,2,0
LDIV,4, , ,2,0
l,8,33
l,7,34
et,1,8   !!!!定义材料和单元类型
R,1,1134.12, ,
et,2,188
SECTYPE,   1, BEAM, CHAN, caogang, 0
SECOFFSET, CENT
SECDATA,100,100,120,8,8,8,0,0,0,0
SECTYPE,   2, BEAM, L, jiaogang, 0
SECOFFSET, CENT
SECDATA,100,60,8,8,0,0,0,0,0,0
mp,ex,1,2.06e5
mp,prxy,1,0.3
kgen,2,9,,,,500
kgen,2,15,,,,500
kgen,2,21,,,,500
lsel,s,line,,1,5,1
lsel,a,line,,51
LATT,1,1,2, ,       7, ,1
lsel,s,line,,6,10,1
LATT,1,1,2, ,       37, ,1
lsel,s,line,,11,15,1
LATT,1,1,2, ,       36, ,1
lsel,s,line,,16,20,1
lsel,s,line,,21,25,1
lsel,a,line,,50
LATT,1,1,2, ,       8, ,1
alls
gplot
kgen,2,2,6,2,,1000
lsel,s,loc,x,580
LATT,1,1,2, ,       38, ,1
lsel,s,loc,x,3180
LATT,1,1,2, ,      39, ,1
lsel,a,loc,x,5780
LATT,1,1,2, ,       40, ,1
lsel,s,line,,52
lsel,a,line,,53
LATT,1,1,1, , , ,2
lsel,s,loc,x,
ldel,all
alls
lesize,all,,,1
lmesh,all
alls
eplot
alls
fini
nsel,s,loc,x,
nplot
d,all,all
/ESHAPE,0.0
nplot
nsel,s,node,,16
nsel,a,node,,20
nsel,a,node,,27
nsel,a,node,,31
nsel,a,node,,38
nsel,a,node,,42
f,all,fy,-750
alls
/solu
solve
/post1
PLDISP,2
发表于 2006-3-10 16:48:03 | 显示全部楼层 来自 江苏南京
大家好,几个简单的例子,也顶一下,希望和大家多多交流,我的Email:swwen82@sina.com
应力集中分析,
/prep7
k,1
k,2,10
k,3,10,10
k,4,,10
k,5,1
k,6,,1
k,7,-0.5,0.5
larc,5,6,7,1
l,5,2
l,2,3
l,3,4
l,4,6
al,all
et,1,63
r,1,1
mp,ex,1,2.06e5
mp,prxy,1,0.3
aatt,1,1,1,
wprota,,,90
wprota,,45,
asbw,all
lesize,5,,,30
lesize,6,,,30
lesize,2,,,30
lesize,3,,,10
lesize,4,,,10
lesize,7,,,10
lesize,8,,,10
amesh,all
/solu          !!!!加载及求解
f,12,fz,100
lsel,s,radius,,1
NSLL,S,1
d,all,all
alls
gplot
NUMMRG,ALL, , , ,LOW
NUMCMP,ALL
solve
/post1     !!!!!后处理
pldisp,2
/eshape,1
PLNSOL, U,Z, 0,1
PLNSOL, S,1, 0,1.0
plnso,s,eqv,0,
拉伸板
/prep7
k,1         !!!!!!建立模型
k,2,15
k,3,35,4
k,4,135,4
k,5,155
k,6,170
k,7,,20
k,8,15,20
k,9,35,16
k,10,135,16
k,11,155,20
k,12,170,20
k,13,,,6
*do,i,1,5
l,i,i+1
*enddo
l,6,12
*do,i,7,11
l,i,i+1
*enddo
l,1,7
l,1,13
lsel,s,loc,z,
al,all
VDRAG, 1, , , , , , 13     !!!!拉伸成体
FLST,2,3,3,ORDE,3          !!!!分割体
FITEM,2,8
FITEM,2,15
FITEM,2,24
KWPAVE,P51X
wprota,,,90
vsbw,1
wpoffs,,,20
vsbw,all
wpoffs,,,100
vsbw,all
wpoffs,,,20
vsbw,all
!!!!!!!!!定义单元类型及材料特性
et,1,95   !!!采用20节点2阶金字塔单元分析
mp,ex,1,2.06e5
mp,prxy,1,0.3
VATT,       1, ,   1,       0
lsel,s,length,,15
lesize,all,,,6
lsel,s,length,,20
lesize,all,,,8
lsel,s,length,,6
lsel,u,line,,18,32,14
lsel,u,line,,20,30,10
lesize,all,,,4
vsel,s,volu,,2,6,4
vmesh,all
lsel,s,line,,18,32,14
lsel,a,line,,20,30,10
lesize,all,,,4
lsel,s,length,,12
lesize,all,,,4
lsel,s,length,,100
lesize,all,,,50
vsel,s,volu,,3
vmesh,all
vsel,s,volu,,1,4,3
SMRT,6      !!!!!!!!!自由网格划分
SMRT,3
MSHAPE,1,2D
MSHKEY,0
MSHAPE,1,3D
CM,_Y,VOLU
VSEL, , , ,       1
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
CM,_Y,VOLU
VSEL, , , ,       4
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VMESH,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
save
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
!!!!!!!!!加载和求解
/solu
zhangkai007 该用户已被删除
发表于 2006-3-10 20:17:50 | 显示全部楼层 来自 江西南昌
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2006-3-11 19:59:14 | 显示全部楼层 来自 天津
我也发一个,和大家一起分享,希望斑竹能给小弟加上一分.((工字梁的弯扭屈曲分析))
/filname,I-beam
/tiltle,buckling
/prep7
et,1,beam189
!以下三行用于定义梁的横截面及相关参数
sectype,1,beam,I,,2
secoffset,cent
secdata,0.15,0.15,0.25,0.015,0.015,0.015,0,0,0,0
!以下三行用于定义材料模型的参数
mp,dens,1,7.85e3
mp,ex,1,2.06e11
mp,nuxy,1,0.2
!以下三行用于定义三个关键点
k,1,0,0,0
k,2,2.5,0,0
k,3,1.25,1,0
lstr,1,2
latt,,1,,1,,3,,1
lesize,1,,,10
lmesh,1
/view,1,1,1,1
/ang,1
/rep,fast
/eshape,1.0                        !显示梁单元的实际截面形状
dk,1,,,,0,all,,,,,,                !定义位移约束
fk,2,fx,-1e6                       !定义自由端的载荷
finish
!以下为特征值屈曲分析与结果显示
/solu
antype,0     !指定分析类型为静力分析
eqslv,spar   !选择稀疏矩阵直接求解器
pstress,on   !打开预应力选项
solve
finish
/solu
antype,1     !特征值屈曲分析
bucopt,lanb,6,0,0   !屈曲模态提取方法及模态提取数
mxpand,6,0,0,1,0.001,   !屈曲模态扩展数及扩展算法选项及
solve
finish
/POST1
SET,FIRST
PLDISP,1
SET,NEXT
PLDISP,1
SET,NEXT
PLDISP,1
PLDISP,1
SET,NEXT
PLDISP,1
SET,NEXT
PLDISP,1
SET,NEXT
SET,LIST
PLDISP,1
!非线性屈曲分析与结果评估
/config,nres,100      ! 设置分析终止条件
/prep7
tb,biso,1,1,2,       !修正材料模型
tbtemp,0
tbdata,,2.0e8,0,,,,
upgeom,0.01,1,1,'I-beam','rst',''
finish
/sol
antype,0
nlgeon,1   !打开大变形选项
outres,all,all  !输入所有子步的结果
arclen,1,0,0,   !打开弧长法
arctrm,U,0.25,2,uy  !弧长法选项设置
nsubst,200,,,1
solve
finish
/post26
nsol,2,2,U,Y,deflection   !指定位移变量
rforce,3,1,f,x,reactionf
/axlab,x,deflection
/axlab,y,reactionf
xvar,2
plvar,3
finish
发表于 2006-3-23 23:06:09 | 显示全部楼层 来自 广东广州
/PREP7
ET,1,PLANE42
ET,2,SOLID45
BLOCK,,2,,1,,1
/VIEW,1,1,1,1
WPOFF,0.5,0.5
CYL4,,,0.2,,,,1
WPOFF,1.0,0.5,0.5
WPROT,0,90
CYL4,,,0.2,,,,1
VSBV,1,2
VSBV,4,3
WPROT,0,0,90
VSBW,1
WPOFF,0,0,-0.5
VSBW,3
WPOFF,0,0,-0.5
VSBW,1
WPROT,0,0,90
KWPAVE,15
VSBW,ALL
VPLOT
/PLOPTS,DATE,0
/TRIAD,LTOP
KWPAVE,19
WPROT,0,90
VSBW,ALL
ESIZE,0.1,0
MSHKEY,1
AMESH,90,102,6
AMESH,106
WPSTYLE,,,,,,,,0
VSEL,S,LOC,X,1,2
ACCAT,58,104
ACCAT,50,89
ACCAT,57,101
ACCAT,49,93
ACCAT,64,80
ACCAT,69,88
ACCAT,68,84
ACCAT,63,75
TYPE,2
VSWEEP,ALL
VSEL,S,LOC,X,0,1
AMAP,38,14,36,38,15
AMAP,10,15,38,34,16
AMAP,42,16,34,40,13
AMAP,45,13,40,36,14
VSWEEP,ALL
SAVE
coucx 该用户已被删除
发表于 2006-3-24 09:11:23 | 显示全部楼层 来自 天津
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2006-3-30 20:14:11 | 显示全部楼层 来自 江苏南京
变截面桥梁分段施工分析(采用ekill实现)
希望版主加分(有些贴浏览不了)
其中有几个VSBW命令的警告,但不影响分析!enjoy!
/prep7
/title,bridge
et,1,solid95
et,2,link8
mp,prxy,1,0.1667
mp,dens,1,2600
mp,ex,1,3.5e10
mp,ex,2,1.95e11
mp,dens,2,7800
mp,prxy,2,0.3
areagjx=1.4e-4
*dim,gjarea,arry,4
gjarea(1)=15*areagjx
gjarea(2)=18*areagjx
gjarea(3)=20*areagjx
gjarea(4)=22*areagjx
F=195.5e3
E=1.95e11
L=1
detL=F*L/(E*areagjx)
istrn=detL/(detL+L)
r,2,gjarea(1),istrn
r,3,gjarea(2),istrn
r,4,gjarea(3),istrn
r,5,gjarea(4),istrn
acel,,9.8
k,2,-2.45,0
k,3,-3.25,0
k,4,-6,0
k,5,-6,-0.18
k,6,-3.25,-0.45
k,7,-2.45,-0.45
k,11,-3.25,-3.9
k,12,-2.45,-3.9
k,13,-2.45,-4.5
k,14,-3.25,-4.5
ksymm,x,2,14,1,100
kgen,2,9,14,1,0,-0.00125*(40-10)*(40-10)+2,10,2000
kgen,2,109,114,1,0,-0.00125*(40-10)*(40-10)+2,10,2000
kgen,2,9,14,1,0,-0.00125*(40-20)*(40-20)+2,20,3000
kgen,2,109,114,1,0,-0.00125*(40-20)*(40-20)+2,20,3000
kgen,2,9,14,1,0,-0.00125*(40-30)*(40-30)+2,30,4000
kgen,2,109,114,1,0,-0.00125*(40-30)*(40-30)+2,30,4000
kgen,2,9,14,1,0,-0.00125*(40-40)*(40-40)+2,40,5000
kgen,2,109,114,1,0,-0.00125*(40-40)*(40-40)+2,40,5000
kgen,2,2,14,1,0,0,1,1000
kgen,2,102,114,1,0,0,1,1000
kgen,2,2,7,1,0,0,10,2000
kgen,2,102,107,1,0,0,10,2000
kgen,2,2,7,1,0,0,20,3000
kgen,2,102,107,1,0,0,20,3000
kgen,2,2,7,1,0,0,30,4000
kgen,2,102,107,1,0,0,30,4000
kgen,2,2,7,1,0,0,40,5000
kgen,2,102,107,1,0,0,40,5000
k,100,0,0,0
k,200,1,0,0
k,300,0,1,0
k,400,0,-4.5,0
k,500,0,-14.5,0
l,400,500
k,21,-3.75,-0.25,-40
k,22,3.75,-0.25,-40
k,23,3.75,-0.25,40
k,24,-3.75,-0.25,40
k,25,-6,-0.1,-40
k,26,-3.75,-0.25,-40
k,27,-3.75,-0.25,40
k,28,-6,-0.1,40
k,29,6,-0.1,-40
k,30,3.75,-0.25,-40
k,31,3.75,-0.25,40
k,32,6,-0.1,40
a,21,22,23,24
a,25,26,27,28
a,29,30,31,32
*do,i,1000,5000,1000
v,2+i-1000,i-1000+7,i-1000+107,i-1000+102,2+i,7+i,107+i,102+i
v,2+i-1000,i-1000+3,i-1000+6,i-1000+7,2+i,3+i,6+i,7+i
v,3+i-1000,i-1000+4,i-1000+5,i-1000+6,3+i,4+i,5+i,6+i
v,7+i-1000,i-1000+6,i-1000+11,i-1000+12,7+i,6+i,11+i,12+i
v,11+i-1000,i-1000+14,i-1000+13,i-1000+12,11+i,14+i,13+i,12+i
v,12+i-1000,i-1000+13,i-1000+113,i-1000+112,12+i,13+i,113+i,112+i
v,100+2+i-1000,100+i-1000+3,100+i-1000+6,100+i-1000+7,100+2+i,100+3+i,100+6+i,100+7+i
v,100+3+i-1000,100+i-1000+4,100+i-1000+5,100+i-1000+6,100+3+i,100+4+i,100+5+i,100+6+i
v,100+7+i-1000,100+i-1000+6,100+i-1000+11,100+i-1000+12,100+7+i,100+6+i,100+11+i,100+12+i
v,100+11+i-1000,100+i-1000+14,100+i-1000+13,100+i-1000+12,100+11+i,100+14+i,100+13+i,100+12+i
*enddo
v,7,12,112,107,1007,1012,1112,1107
cskp,100,0,100,200,300
vsel,all
csys,100
vsymm,z,1,100,1,10000,0,0
csys,0
asel,s,loc,y,-4.5
vdrag,all,,,,,,1
allsel
vsel,all
wprota,0,0,90
wpave,2.7
vsbw,all
wpave,3
vsbw,all
wpave,-3
vsbw,all
wpave,-2.7
vsbw,all
wpave,2.45
vsbw,all
wpave,3.25
vsbw,all
wpave,-3.25
vsbw,all
wpave,-2.45
vsbw,all
wpave,2.2
vsbw,all
wpave,3.5
vsbw,all
wpave,-3.5
vsbw,all
wpave,-2.2
vsbw,all
wpave,1.95
vsbw,all
wpave,3.75
vsbw,all
wpave,-3.75
vsbw,all
wpave,-1.95
vsbw,all
vsel,s,loc,y,-0.45,0
vsba,all,1
vsba,all,2
vsba,all,3
allsel
vglue,all
vatt,1,1,1
lsel,s,loc,z,-10,10
lsel,r,loc,y,-0.25
lsel,r,loc,x,2.7
cm,gj1_1,line
latt,2,2,2
allsel
lsel,s,loc,z,-10,10
lsel,r,loc,y,-0.25
lsel,r,loc,x,3
cm,gj1_2,line
latt,2,2,2
allsel
lsel,s,loc,z,-10,10
lsel,r,loc,y,-0.25
lsel,r,loc,x,-3
cm,gj1_3,line
latt,2,2,2
allsel
lsel,s,loc,z,-10,10
lsel,r,loc,y,-0.25
lsel,r,loc,x,-2.7
cm,gj1_4,line
latt,2,2,2
allsel
lsel,s,loc,z,-20,20
lsel,r,loc,y,-0.25
lsel,r,loc,x,2.45
cm,gj2_1,line
latt,2,3,2
allsel
lsel,s,loc,z,-20,20
lsel,r,loc,y,-0.25
lsel,r,loc,x,3.25
cm,gj2_2,line
latt,2,3,2
allsel
lsel,s,loc,z,-20,20
lsel,r,loc,y,-0.25
lsel,r,loc,x,-3.25
cm,gj2_3,line
latt,2,3,2
allsel
lsel,s,loc,z,-20,20
lsel,r,loc,y,-0.25
lsel,r,loc,x,-2.45
cm,gj2_4,line
latt,2,3,2
allsel
lsel,s,loc,z,-30,30
lsel,r,loc,y,-0.25
lsel,r,loc,x,2.2
cm,gj3_1,line
latt,2,4,2
allsel
lsel,s,loc,z,-30,30
lsel,r,loc,y,-0.25
lsel,r,loc,x,3.5
cm,gj3_2,line
latt,2,4,2
allsel
lsel,s,loc,z,-30,30
lsel,r,loc,y,-0.25
lsel,r,loc,x,-3.5
cm,gj3_3,line
latt,2,4,2
allsel
lsel,s,loc,z,-30,30
lsel,r,loc,y,-0.25
lsel,r,loc,x,-2.2
cm,gj3_4,line
latt,2,4,2
allsel
lsel,s,loc,z,-40,40
lsel,r,loc,y,-0.25
lsel,r,loc,x,1.95
cm,gj4_1,line
latt,2,5,2
allsel
lsel,s,loc,z,-40,40
lsel,r,loc,y,-0.25
lsel,r,loc,x,3.75
cm,gj4_2,line
latt,2,5,2
allsel
lsel,s,loc,z,-40,40
lsel,r,loc,y,-0.25
lsel,r,loc,x,-3.75
cm,gj4_3,line
latt,2,5,2
allsel
lsel,s,loc,z,-40,40
lsel,r,loc,y,-0.25
lsel,r,loc,x,-1.95
cm,gj4_4,line
latt,2,5,2
allsel
!定义组
cmsel,s,gj1_1
cmsel,a,gj1_2
cmsel,a,gj1_3
cmsel,a,gj1_4
cm,gj1,line
allsel
cmsel,s,gj2_1
cmsel,a,gj2_2
cmsel,a,gj2_3
cmsel,a,gj2_4
cm,gj2,line
allsel
cmsel,s,gj3_1
cmsel,a,gj3_2
cmsel,a,gj3_3
cmsel,a,gj3_4
cm,gj3,line
allsel
cmsel,s,gj4_1
cmsel,a,gj4_2
cmsel,a,gj4_3
cmsel,a,gj4_4
cm,gj4,line
allsel
lesize,1
lsel,s,,,gj1
lsel,a,,,gj2
lsel,a,,,gj3
lsel,a,,,gj4
esize,1
lmesh,all
allsel
vmesh,all
nummrg,all
numcmp,all
nsel,s,loc,z,-1,1
esln,s,1,all
cm,kuai0,elem
allsel
nsel,s,loc,z,-10,-1
nsel,a,loc,z,1,10
esln,s,1,all
cm,kuai1,elem
allsel
nsel,s,loc,z,-20,-10
nsel,a,loc,z,10,20
esln,s,1,all
cm,kuai2,elem
allsel
nsel,s,loc,z,-30,-20
nsel,a,loc,z,20,30
esln,s,1,all
cm,kuai3,elem
allsel
nsel,s,loc,z,-40,-30
nsel,a,loc,z,30,40
esln,s,1,all
cm,kuai4,elem
allsel
nsel,s,loc,y,-14.5
d,all,all
allsel
/solu
eqslv,pcg
time,1
nlgeom,on
nropt,full
estif,1e-5
allsel
ekill,all
esel,s,,,kuai0
ealive,all
esel,s,live
nsle,s
nsel,inve
d,all,all,0
allsel
nsel,s,loc,y,-14.5
d,all,all
allsel
solve
save
time,2
allsel
esel,s,,,kuai1
ealive,all
allsel
ddele,all,all
esel,s,live
nsel,s
nsel,inve
d,all,all,0
allsel
nsel,s,loc,y,-14.5
d,all,all
allsel
solve
save
time,3
allsel
esel,s,,,kuai2
ealive,all
allsel
ddele,all,all
esel,s,live
nsel,s
nsel,inve
d,all,all,0
allsel
nsel,s,loc,y,-14.5
d,all,all
allsel
solve
save
time,4
allsel
esel,s,,,kuai3
ealive,all
allsel
ddele,all,all
esel,s,live
nsel,s
nsel,inve
d,all,all,0
allsel
nsel,s,loc,y,-14.5
d,all,all
allsel
solve
save
time,5
allsel
nsel,s,loc,z,-40,40
esln,s,1,all
ealive,all
allsel
ddele,all,all
nsel,s,loc,y,-14.5
d,all,all
allsel
solve
save
GMT+8, 2026-1-12 13:30 , Processed in 0.061526 second(s), 20 queries , Gzip On, MemCache On.
