三角形接法的的一次侧,他的0电位怎么来设置,例如这一段程序:
et,4,circu124,5 !Stranded Coil element(To FEM domain)
et,5,circu124,2 !capcitor
et,6,circu124,4,1 !Independent Current Source(low)
et,7,circu124,4,1 !Independent Current Source(high)
et,13,circu124,0 !连线电阻
r,4,1 !Symmetry factor for stranded coil
r,5,1/25981.58/2/3.1415/400 !电容值
r,6,,84.75,400,,-120, !Independent volu Source(lowA)幅值和相位353.6
r,7,,84.75,400,,0, !Independent volu Source(lowB)幅值和相位
r,8,,84.75,400,,+120, !Independent volu Source(lowC)幅值和相位
r,9,,36722,400,,-120, !Independent volu Source(highA)幅值和相位
r,10,,36722,400,,0, !Independent volu Source(highB)幅值和相位
r,11,,36722,400,,+120, !Independent volu Source(highC)幅值和相位
r,13,1e-10 !连线电阻
N,,-M0,D10/2,Hc/2!-dh1
*get,naff,node,,num,max
N,,-M0,-D11/2,Hc/2!-dh1
*get,nafs,node,,num,max
N,,0,D10/2,Hc/2!-dh1
*get,nbff,node,,num,max
N,,0,-D11/2,Hc/2!-dh1
*get,nbfs,node,,num,max
N,,+M0,D10/2,Hc/2!-dh1
*get,ncff,node,,num,max
N,,+M0,-D11/2,Hc/2!-dh1 !低压包6个接头节点
*get,ncfs,node,,num,max
N,,-M0,-D22/2,-Hc/2!+dh1
*get,nass,node,,num,max
N,,0,-D22/2,-Hc/2+!dh1
*get,nbss,node,,num,max
N,,+M0,-D22/2,-Hc/2!+dh1
*get,ncss,node,,num,max
N,,0,-D21/2,Hc/2!-dh1 !高压包4个接头节点
*get,nn0,node,,num,max
type,13
real,13
e,nafs,nbff
e,nbfs,ncff
e,ncfs,naff !三角形连接
cmsel,s,lowA,volu
nslv,s,1
*get,nafmin,node,,num,min
cp,next,CURR,all
!cp,next,EMF,all
N,,-M0,(D10-D11)/4,Hc/2+2*D
*get,nan,node,,num,max
type,6
real,6
e,naff,nafs,nan !lowA Independent volu Source fed
type,4
real,4
e,naff,nafs,nafmin !lowA Stranded Coil(To FEM domain)耦合
cmsel,s,lowB,volu
nslv,s,1
*get,nbfmin,node,,num,min
cp,next,CURR,all
!cp,next,EMF,all
N,,0,(D10-D11)/4,Hc/2+2*D
*get,nbn,node,,num,max
type,6
real,7
e,nbff,nbfs,nbn !lowB Independent volu Source fed
type,4
real,4
e,nbff,nbfs,nbfmin !lowB Stranded Coil(To FEM domain)耦合
cmsel,s,lowC,volu
nslv,s,1
*get,ncfmin,node,,num,min
cp,next,CURR,all
!cp,next,EMF,all
N,,+M0,(D10-D11)/4,Hc/2+2*D
*get,ncn,node,,num,max
type,6
real,8
e,ncff,ncfs,ncn !lowC Independent volu Source fed
type,4
real,4
e,ncff,ncfs,ncfmin !lowC Stranded Coil(To FEM domain)耦合
我不知道怎么来定我的0电位,
我也不知道,在ansys里每个回路里必须要有一个束缚电压自由度,是么?
[ 本帖最后由 ponderadams 于 2007-4-6 10:47 编辑 ] |
