- 6
- 2004-5-11
发表于 2005-12-8 17:20:22
来自 吉林长春
Re:求教:ALGOR中关于梁单元三角形荷载的加法
这是在帮助文件中的内容,会对你的问题有帮助
Applying a Distributed Load
If you select one or more beam elements using the "Selection: Select: Lines" command and right click in the display area, you can select the "Add" pull-out menu and select the "Beam Distributed Loads..." command to add a distributed load each beam element.
If the magnitude and direction of the load will be constant across the length of each selected beam, specify the magnitude of the load per unit of length in the "Magnitude" field and the direction of the load in the "Direction" section. If the magnitude or direction of the load will vary across the length of the each selected beam, deactivate the "Uniform" checkbox and specify the magnitude of the force per unit of length at each end in the "I-Node Magnitude" and "J-Node Magnitude" fields and the direction in the "I-Node Direction" and "J-Node Direction" sections. The magnitude of the force will vary linearly between the nodes. This will be done on a per-beam basis.
If you are applying a non-uniform load to the beam, you can have the load start and end at any point along the beam. This will be done by specifying a ration of the length of the beam in two "ratio from I-Node" fields. The first field will determine how far from the I-Node the load starts. The second field will determine how far from the I-Node the load ends. For example, if you want a load to be applied only along the third-quarter of a beam, you would specify 0.5 in the first field and 0.75 in the second field. |
