- 2008-9-2
发表于 2008-10-4 10:00:23
来自 大连理工大学
原帖由 demi89 于 2008-10-3 20:09 发表
不知道 你用的什么前处理
不过他说你没定义材料 你可以通过编辑k文件 看看
用的ANSYS前处理,在前处理中已经定义了的,而且划分网格的时候也定义了材料属性,最后写入K文件的时候竟然说没有显示材料,太奇怪了,不过我写入K文件中看了单元的属性,还是有定义的属性的,不过在材料一栏里没有,我添加上了,应该不影响计算的吧
看了下MESSAG文件 出现了这个,不知道是不是错误原因
Date: 10/04/2008 Time: 15:07:15
___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version: 970 Date: 07/30/2004 |
| Revision: 5434 Time: 15:01:01 |
| Features enabled in this version: |
| ANSYS Database format |
| Shared Memory Parallel |
| Licensed to: |
| Platform : |
| OS Level : WINDOWS XP |
| Hostname : gao |
| Precision : Single precision (I4R4) |
| Unauthorized use infringes LSTC copyrights |
Input file: F:\ANSYS\1\EXPLOS~1.K
The native file format : 32-bit small endian
Memory size from command line: 230000000
expanding memory to 230000000
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Explicit Finite Element code. *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2003 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
contracting memory to 2267952
expanding memory to 4515904
expanding memory to 8097448
expanding memory to 18240232
expanding memory to 18270232
expanding memory to 18330232
expanding memory to 18363085
expanding memory to 18424879
expanding memory to 24991135
expanding memory to 25587059
expanding memory to 26182983
expanding memory to 26778907
expanding memory to 36876691
expanding memory to 37472615
LS-DYNA will perform a structural only analysis
LS-DYNA user input
ls-dyna (version 970 ) date 07/30/2004
expanding memory to 3159
expanding memory to 25797
expanding memory to 6770064
expanding memory to 24545028
expanding memory to 25105996
expanding memory to 41323599
expanding memory to 41325605
contracting memory to 41324253
expanding memory to 41362113
expanding memory to 52678324
expanding memory to 54466096
expanding memory to 122794521
expanding memory to 122833810
expanding memory to 122840293
expanding memory to 129120184
contracting memory to 126960468
expanding memory to 128748777
contracting memory to 126973396
expanding memory to 127011403
contracting memory to 127011403
expanding memory to 127089691
expanding memory to 127089771
contracting memory to 127089771
expanding memory to 128877543
expanding memory to 128878070
expanding memory to 128878082
expanding memory to 129215582
expanding memory to 129425426
expanding memory to 131937038
expanding memory to 132146882
expanding memory to 134658494
expanding memory to 211103897
expanding memory to 213487713
expanding memory to 213487719
contracting memory to 213487719
expanding memory to 215731671
The LS-DYNA time step size should not exceed 0.115E+03
to avoid contact instabilities. If the step size is
bigger then scale the penalty of the offending surface.
1 t 0.0000E+00 dt 2.84E-01 flush i/o buffers
1 t 0.0000E+00 dt 2.84E-01 write d3plot file
之后就说求解器出现错误,需要关闭,我快疯了,实在不明白哪里出错了
[ 本帖最后由 云琅08 于 2008-10-4 15:15 编辑 ] |
